Brief Description: install and wire a battery hot buss
installed a 6 port fuse block to the right side of parking break on the same bulkhead ran 14awg wire from battery to the fuse block labeled each end of the wire and covered with clear shrink tube crimp on a ring connector on the fuse block end and used more shrink tube for protection left battery end of wire hanging for now but the plan is to install a 10 amp inline fuse close to either the pos battery terminal or the battery end of the master relay,
