Bill & Brendas RV-8 QB
Date:  9-20-2013
Number of Hours:  1.00
Brief Description:  final pitot static tube runs and attacment
I had ordered a bulkhead fitting for the pitot tube wing to cabin transition and also a y connector to finish static sytem.
changed a couple of fittings on the back of gages
cut some better lengths of static tube on manifold
used the red colored tube from pitot tube to use from ASI to the bulkhead fitting in wing root
drilled 9/16 hole with unibit for the bulhead fitiing for piutot tube
drilled a hole in left gear tower for the pitot tube
ran the pitot tube from bulkhead fitting to the ASI
tightened up all pitot static fittings
red loc tight to nuts on bulkhead fitting and covered out board port with tape
red pitot line from wing bulkhead fitting to ASI t fitting and on to Auto pilot with clear tube
hole drilled in left gear tower to accomodate the pitot tube
Pitot tube from ASI terminates at the bulkhead fitting in wing root area under left console
