Brief Description: Attach wire harness to back of radio and transpond
Installed the wire harness plates to the back of the radio and transponder trays and then test fit in the fuse. It was real close to the left brake line but I just bent the line away some by hand and that gives me much more room. I think it will work ok I did note that the transponder does not seat in as dep as when I fit it w/o the wire plate installed. So the face plate sticks out further than I wanted. I will need to look into this more and make sure its seated fully or is something stopping a full seat.
Radio and xpr harness' temp install to see if it fits. Messy but fits.
amt of clearence from brake line to radio harness bracket
