Friend of mine laid a spool of safety wire on my step stool just below the prob and positioned it so very close to the tip. I already had the plugs out and so I carefull roted prop trying not to let the plane budge and checked the difference on the othe blade tip. Could only see very slight difference of maybe a 1/32 inch possibly. It was not much if any at all. I did this several times and the results were the same. Bolts were not torqued down yet so this will need to be done again butat least it appears that the prop is tracking true. Thats GOOD!
I also reinstalled the rear stick after some real light wet sanding on the lip edge.
