Bill & Brendas RV-8 QB
Date:  8-4-2013
Brief Description:  Trim emp fairing to fit and drill bottom fairing f
Much time was spent trying to figure how this should gobut basicly the upper fairing needs to butt up against the lower fairing strip about miday across the access plate. I clecoed it on and match drilled two holes into access plate and thru the longeron 7/64. Plans call for #36 but I dont have one and 7/64 is pretty darn close. Close enough for tapping a screw hole anyway.
The upper fairing required two holes as well but they are not pre punched and require some measurements first. I did this on both sides.
The lower fairing strip requires up drilling to &/64 as well and I did this both sides all except for two holes on each side that I cant reach cleanly due to the HS in the way. Since these holes will all be tapped for 6-34 screws, the HS will once again come off. I can do that as well as install all the plate nuts while epoxy cures again on the canopy skirts.
Upper emp fairing
Upper emp fairing
Upper fairing meets the lower over access plate
After trim and sanding
