Bill & Brendas RV-8 QB
Date:  8-3-2013
Number of Hours:  1.00
Manual Reference:  dwg 85
Brief Description:  Empenage fairing drilled and clecoed
Marked crossing lines with a sharpie on the screw holes in VS and HS that are for the fairing.
Taped the fairing in position and started drilling from fwd holes working back.
I had drill bit wandering on very first hole so I tried using the hole finder strap. That worked well enough and so I continued with it for all the HS match drilling.
The starp was a problem for the VS holes because the fairing too tight. The holes beneath the fairing are easily visible with lighting from other side however. So I simply used a center punch andfollowed with the #40 drill clecoing as I went along. Turned out well enough.
There are plenty of gaps to deal with but will worry about that later. Moving on!
empenage fairing drilled and clecoed
