Brief Description: Initial placement of VS to HS fiberglas fairing
I first had to re install the VS and HS. Located and placed the Fairing in position to check fit. Some notable gaps present on rt side along top edge.....YUK! and excess material on aft end. I also noted that I dont have any plate nuts installed on VS bottom rib and will probably need to install them so that this fairing will be removable. I will probably working this next and while Im working the canopy skirts, let the fun begin!!
