Brief Description: Tail light mounting ring final instal and ground w
2 Hours?? Yes! I could not get this housing wire secured to the darn mounting ring to save my life but persistence paid off and now I can tell you I will never unscrew that wire again.
Started by riviting on the mounting ring for tail light/strobe. I left one hole for a screw to attach a ground per plans.
Once rivited, I sanded all around the mounting ring to remove edge.
Drilled the last rivit hole to 9/64 and then counter sunk for the #6 screw head.
Managed to get a ring type connector secured to the screw with lock nut. Verified continuity.
Put dab of solder on ring conector and nut since I dont plan on removing it.
Added shrink tube to the connection and crimped on a but splice on end of the pig tail for the wire to rib brace. I figure that since this cap will be rivited on, this particular wire does not need to be removable.
Tail light mounting ring rivited on
Mounting surface sanded to fit
One hole up drilled to 9/64 and ring terminal with ground wire attached via #6 screw and lock nut
