Brief Description: Final stick grip wire connections at terminal bloc
I had run 3 wires previosly from behind panel area to the wire block for stick grip switches. These were for the index, left and right switches. Index is for the auto pilot engage. disingage. The right stick button is the ident button on transponder and the left is open or undecided still. This should be all the wiring necessary beneath the floor and I should be clear to install it again. Wont rivit down though until I complete all electrical function tests.
Ident button ring connector installed
Final connections made to the Control stick grip block
