Brief Description: sanded the skirt halves joint and more epoxy appli
I sanded down the glass and epoxy on skirt joint aft. I then mixed up some epoxy and cabosil and applied with a squeege. I couldnt remove the skirt by myself so ill wait for help to remove before I work on glassing the joint on inside.
