Brief Description: Join left and right canopy skirts together
light sanded the last coat of filler primer and then clecoed the skirts to the frame.
Thought I would need a way to block the skirts down at the joint but turns out I didnt need to after all. I did scuff sand the area in prep for the glass
Covered the areas I didnt want epoxy with wax paper and folded a bit of paper to build up about 3/32 gap above rail to glass in the aft center.
Glassed in two ovelapping layers of BID and covered with peel ply and now the wait for it to cure.
