Bill & Brendas RV-8 QB
Date:  8-19-2012
Number of Hours:  0.75
Brief Description:  skirts-13
Re drilled the problem holes taht I had added some cloth and resin to on back side. I then top filled a couple of the holes with a flox and resin mix and scraped off excess. I can see from back side where I had drilled so should be able to drill a final time and have a clean hole and surface.
Added a layer of cloth and resin to the left skirt top front edge. Still working on increasing the edge distance in that area.
