Brief Description: install fittings on the pressure manifold
used permatex thread sealant to the treads of pipe end of the two an fittings being carefull to not get below the tread line. Also added the sealant to the two brass plugs, Tightened everything down and marked with lacqor marks. the pic below is turned off 90 degrees. the manifold is mounted to firewall horizontal note: i did not add any sealant to the threads of the flared ends of fittings because that is not advisable
pessure manifold with fittings for oil and fuel pressure lines
