1. Applied one coat of engine white enamel to the batery tray and mounting parts. I will need to do the other side and possibly a second coat later. These parts were previously primered but not with a high heat primer so im not sure the high heat top coat is going to be negated or not. On the other hand, I dont expect the battery or the battery tray to come anywhere close to 550 degrees. if it does, we got bigger problems than some paint bubbling up..
high heat engine enamel
battery tray mounting parts painted with white enamel
