I finished cutting the batery tray brackets to plans dimensions and then bent the ends 32 degrees in the vice. Marked wheer the aprox drill hole locations will be but will drill in assembly later.
Finishe the cuts and radius the edges of the lower attach brackets and then marked the hole locations again
Spent a great deal of time trying to figure out where on the firewall this is mounted. The drawing is not real clear here.
