Brief Description: brake line air bubble removal attempt 2
Filled oil can up with brake fluid again and used it to push air bubbles out of the lines. First the left and then moved to right side. Noticed that the left had another bubble appear so I went back to it again. Looked good for about an hour when two super small bubbles appeared again. I dont know if air is being introduced from the oil can or not. Will let it sit for a while again and try again if required.
