Brief Description: Thread seal to master cylinders and misc work
Spent quite awhile today removing the fittings from the two brake master cylinders and adding some permatex thread seal to them and reinstalling. I also removed the parking brake and then its fittings to do same thing and then reinstalled. It probably wasnt necessary, but I removed the nylon tee fitting from the brake fluid resivoir to add sealent there as well.. Hope the brake lines inside the cabin are good to go now. I will try and figure out a way to pressure test.
I reattached the rudder cables to the firewall and the rear seat pedals
I had the GIB Brenda make me a template for the switches that go in the right side switch console.
Cleaned up the work benches and then took the ole citabria for a short flight.
