Brief Description: P brake hold lever 3 and rt brake line redo
Marked The transition valve position zone on my valve lever bracket. Its 27.5 degrees on each side of center. I then drilled 3 holes slightly larger than the plunge pin along the arc top and bottom. The top 3 holes will be the open postion and the bottom 3 will be closed positions.
I had interferance from the baggage shelf lip and the bottom mounting bolt for the parking brake so I simply nade a reief vut there and then trial fit.
made a new brake line for the rt side from parking brake to the bottom of rt landing gear tower It came out ok but you can see the slight imperfections of a straight and crisp line. It will be fine and hardly visible.
Lever position bracket drilled
Relief cut for p brake mounting bolt in baggage shelf lip
