Bill & Brendas RV-8 QB
Date:  9-16-2012
Number of Hours:  1.50
Brief Description:  Parking brake lever lock bracket 1
decided to make a template and trial bracket for the parking brake locking lever. Drilled two holes in the bracket for the center bolts. Bent the plate in my metal brake and then drew an arc.
The Arc will have some holes drilled for a pin plunger to engage and thus lock lever in either an open or closed position. Will do that tomorrow hopefully. I will either double up this bracket so its sturdy or try to make another one from some thicker material
template bent in the metal brake
made the arc line for the lever
