Removed the tail light and then prep the bottom cap joint area by sanding and cleaning and masking off.
Cut strips of 3 oz glass aprox 1.5 to 2 inch wide the length of rudder cap seem Wetted the area and lay in the glass and cover with epoxy using small brush covered with peel ply and smoothed out with plastic spatula
