Brief Description: sanding some pin holes and more sanding primer add
Stopped by hangar after work and intended to sand on canopy skirts. Didnt happen! I sanded the empenage tips lightly( minus the rudder) and it seams that pin holes look gone but there were some slight depressions on a tip or two, After sanding I went ahead and sprayed on another coat of sanding primer to all. I will sand down lightly again with 180 and 220 and hopefully leave em alone for awhile.
