Bill & Brendas RV-8 QB
RV-8
Fiberglass tips
7-21-2013
sand and reapply micro etc
1. sanded elevator tips down
2. applyy straight epoxy to them to seal and fill
3. Removed peel ply fro hs tips(bottom sides) and sanded well
4. Applied micro to the glass and set aside to cure
5. sand and feather the vs tip and apply straight epoxy to it as well
note: The sanding takes much longer than expecte!
Elevator tip sanded after a layer of super fill.
HS tip sanded after glassing and then micro applied
VS and both elevators curing with plain epoxy skin coats
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
