1. Sanded down the left and right elevator tips aagain and then applied superfill
2.Removed the HS from fuselage and then applied a strip fo galss cloth to the underside of both tip to aluminum gap line. Covered with peel ply.
3. Not related to the tips but used the left over micro to apply a small square of glas to the underside of the lower rt console where I had the two CB holes that I dont want. Covered them and then filled with first coat of micro on top side.
