Brief Description: apply micro to VS and rudder final sides.
Applied the micro slurry to the remaing side of the VS and rudder tips. This complets the first coat of VS, rudder, and two elevators tips. Now the sanding begins and then fill work.
After sanding down micro applied yesterday, I applied a second thin coat of micrp
Sanded down the top sides of HS tips and then brushed on a thin coat of epoxy
R top HS tip after glass, 1 coat micro, sanding, 1 coat plain epoxy brushed on
