Brief Description: Glass layup complete on both HS tips and VS tip
Remnoved the foam by pouring small amount of acetone on it. Dissolved in about 10 seconds!
Cut out strips for a second and overlapping reinforcement in side the HS tips. Also cut two sets (2nd set wider than 1st) for the VS tip. Laid out foe easy access and made the epoxy mix. Brused in the epoxy with foam brush to get nice and slippery and then laid in the 2nd layer of strips for both HS tips. Moved on to the VS and did the same. Laid in the 2nd set emediatel after the first. Note how the glass just dissapears when saturated.
Laid the tips face down on wax paper to cure
Will build the faces up flush with micro next
Tips, glass strips, applicators, and epoxy ready to go
