Bill & Brendas RV-8 QB
Date:  4-12-2012
Number of Hours:  0.75
Brief Description:  fiberglass elevator tips 7
Sanded the epoxy applied to the left elevator tip and counter weight. It will need another application or two but is good enough to set the 1/8 inch gap from the HS tip later.
Also sprayed another coat of smoke gray on baggage floor. Got a bunch of pimple sized bumps this time and I dont know why. Ill check it after it cures and address it then
