Mixed a small batch of epoxy and micro ballons to a honey type consistancy. Im new to this so trial and error is in order. Applied the mix to the lead counter weight faces with a plastic spatula. I also had a strip of electrical tape to define where I want it to transition to the aluminum. This too is just a guess and trial. Im not sure how it will work. I also cut two pieces of peel ply from some polyfiber cloth i had left over and pressed them lightly on to the mix. I may not realy need to do this but it may help keep the mix from sagging and will also leave a nice finish when its peeled off. We shall see! Later on I peeled off the ply and it looks pretty good. Will need to sand and feather out the edges and then add more as needed next time.
First batch of west system micro epoxy
Micro applied to counterweight face and covered with peel ply
