Bill & Brendas RV-8 QB
Date:  3-21-2012
Number of Hours:  4.00
Brief Description:  Fiberglass tips- HS and elevators
1. Started out today doing a little file work on the transponder cut out. Its a bit better but still too snug top and bottom. Decided to move on to something else today
2. Checked for the necessary 1/8 inch gap between the elevator counter weights and the Horizontal stabilizer tips. I had previously done this and made the cuts in the aluminum but now I realize that I dont have the proper clearence and will need to trim some more. I made some new cut lines and will probably cut them after I have the elevator tips done.
3. Cut the HS tips to fit. They will need to be trimed for fit later but now they at least fit in place and I can judge better how much more will need to be trimmed off after I reinstall the elevators
4. Prepared 4 aluminum strips to use as a backing plate on the inside edges of the tips for when the pop rivits are pulled so that they wont pull through the fiberglass
5. Mixed a batch of 2 part epoxy and epoxied the strips in place on each tip and then clamped with a bunch of clamps.
HS tips put in place and marked for 1st cut
Left side elevator tip cut and fit with extra room for epoxy
Alum strips epoxied inside edges of elevator tips
