Bill & Brendas RV-8 QB
Date:  3-17-2012
Number of Hours:  1.00
Brief Description:  rt elevator fiberglass tip1
Started on the right elevator fiberglass tip. Need 1/2 inch on fiberlass lip so that it does not lay up n the rib flange. Marked a line for cutting and then cut off excess with dremel tool. Sanded to line on belt sander. Cut out a notch on each flange to go around the lead counter weight and then test fit. Sanded lightly until fit looked good.
mark line for 1/2 inch joggle
Cut off excess with dremel
test fit. Check for interference with rib flange
