Brief Description: installing the flightcom intercom and acs starter
I guess I decided to start putting the panel in permanately. Hopefully not too soon! I squeezed the rivits into those 4 open holes at the top center of apron Started to rivit the apron to the side skin.2 ea on each side. But I had folded the second rivit over and decided I can drill it out tomorrow.
Installed the flightcom intercom in the apron right side and attached the harness to it. Installed the two knobs on the front
Installed the ACS key switch. I had the wires in aprox position for it but realized I hadnt left enough slack.I cut a couple ties and then pulled 4 of the wires for more slack. I need to find the wire attach plans.
Rivit the final 4 rivits in the upper appron
Intercom installed. Wire hook ups still incomplete
