Brief Description: Dimmer heat sink-2 and encoder mounted
Sanded the jb weld applied to a bad mounting hole for the dimmer circuit board no.2 on the access door. Touch up painted Installed the dimmer no 2 circuit board and secured with supplied hardware and lock tite red
Decided to mount my altitude incoder in the center of the access door behind panel. This location is behind the garmin 696 and will have plenty of room. I have the connections to the starboard side. This will allow easy acces for adjustments when door is pulled open into the baggage comp. There is also a thumb screw that holds unit to mount and can easily be disconnected from mount if necessary. I think its a good plan but wont know untill further connections are made
view from panel side. Both dimmer modules and the encoder
encoder and one dimmer module on door in open position
