Bill & Brendas RV-8 QB
Date:  8-9-2013
Number of Hours:  1.25
Manual Reference:  TE810-1
Brief Description:  Cockpit dimmer potentiometer install x2
Temp installed the dummy warning lights in my panel
Temp installed the two trim indicators
Temp installed the two dimmer potentiometers. These have knob stems taht stick out further than i like so i trimmed them back a bit with my dremel cut off wheel
The potentiometers have heat sink control boards and I mounted both. One to the access door behind panel left side and the other in the apron area. Didnt do a very good job positioning the 4 mount holes. The second heat sink had a hole that I decided to fill with jb weld and will finish tomorrow.
These dimmers can handle up to a max of less than 1.5 amps
I have one to control the radio and transponder and other gauge lights together. The other will be for other cockpit lighting. Subject to change
Potentiometers. One cut to more desired length
Potentiometers install. See the difference in length. Cut the other one post pic
Heat sink #1 installed port side in apron area. #2 is just to right but had problem with a drilling.
