Brief Description: ACS ignition switch back plate fab -2
1. Finished filing the key plate until it fit the switch barrel and then sanded out the file marks
2. Traced the outer edge of faceplate onto the backplate and then cut and trim and polish down. I did this only so that it wouldnt be too noticable from behind. Nobody will realy ever see it but I know its there! So at least it looks nice enough
3. After deciding on the orientation of face plate, I marked the duplicate location with the back plate, Drilled the rivit holes, deburr etc and then rivited with two flush oops rivits in location that will be concealed with the face plate.
