1. Lay out and mark as accurately as I could the cut outs for the aileron and elevator electric trim indicators. There is not much overlap from the face plate on two sides so slow and easy is the way to go.
2. Used the dremel to make the cuts and then filed away at it until the units fit.
3. After deburing the edges some, I used the unit to match drill the mounting holes to 5/16
4. Polished up the edges
The Dynon has the capabliity to handle the two servos but I have limited number of optons I can add to it. I decided to use the Ray allen indicators instead and that will free up the dynon to display something else.
I mounted the indicators in a place that should be shielded from direct sun light
