Bill & Brendas RV-8 QB
Date:  8-26-2012
Number of Hours:  1.00
Brief Description:  Elt remote switch hole cut in panel
Decided to put the ELT remote switch in the panel right apron. I would have perfered that the hobbs go here but it didnt quite have enough clearence above the intercom as I had hoped for.
Marked cut out and drilled a 3/32 hole in each corner for corner radius. I then used a dremel to carefuly cut the oppening. It then required plenty of file work before the unit fit. Once in, I cllamped and drilled the mounting holes using the unit to match drill. Tomorrow I need to sand the cut out smooth.
Elt remote cut out made
