Bill & Brendas RV-8 QB
Date:  2-25-2012
Number of Hours:  1.00
Brief Description:  panel 3
no pics today
Using the mounting diagram for the truetrak control head, I laid out the mounting hole locations first. The jig works good for 3 of 4 holes but the 4th is in a didfferent position. When I had the lines drawn for a squae refrence, I was then able to mark the lobe cutouts and radius for the two knobs just below the bezel. When finished, I realized I was in the center hole where I intended to put the altimeter! So that was somewhat wasted effort. At least the 3 screw holes are the same for the altimeter. I will need to remark tomorrow.
