Bill & Brendas RV-8 QB
Date:  2-22-2012
Number of Hours:  3.50
Brief Description:  Cut vent and intercom holes in panel side skirts
Set the drill press up with a wood base and secured a test piece of aluminum to it to try out some circle cuts with the man killer. Set the speed to 500 rpm and made some practice cuts. When I was happy with the adjustments, I made the hole cut for the air vent. Cleaned up the hole edge and then marked for drill locations for the srews and then drilled for # 8 screws.
On the rt side I cut the hole for the flightcom intercom plate. Marked the screw hole locations with a jig and drilled #27 for #6 screws.
Spent some time figuring how I want to run the pitot line into the fuse from the wing. I had planed on running some tygon tube with 1/4" ID but have decided to use only a short piece as a junction between the 1/4 od aluminum line to a a line similar to the static line from Vans. It will be a simple fit and very uncomplicated. I will order some more line for this.
I also need to order some hardware to mount the steam gauges
Cutting the holes in apron with the mangler
Vent hole cut and vent installed for fit
The intercom hole cut and plate temp installed
