Bill & Brendas RV-8 QB
Date:  1-25-2012
Number of Hours:  1.25
Brief Description:  Drill hoes in bottom skin to bottom inbd wing ribs
Todays task was to match drill the 11 holes in ech inbd wing rib to the bottom fuselabe skins.
A note here: It would have been a good idea to have drilled the wing rib holes to at least #40 PRIOR to fitting the wing! I dont know why I didnt do it. All I did was mark the hole location with lines as per plans. I had purchase a hole finder from Avery in both #40 and # 30 but they wont work as designed if the hole your trying to slip into isnt quite big enough-right??
Well, The hole finder still worked well enough even though it didnt slip all the way in. I could still line it up on the hole adn then drill them. I then clecoed every other hole and drilled all up to #30 as per plans. It all worked out just fine.
Using the hole finder to match drill bottom skins
Not to hard to do if the plane and wings are high enough
Drill the #40s up to #30 and clecoed
