Bill & Brendas RV-8 QB
RV-8
Wing Fitting
1-21-2012
Temp install left wing and then level the fuselage
1. Put the left wing on with a 7/16 tapered bolt/pin into the uper and lower holes in spar. Np need to put all the bolts in for fitting.
2. Leveled the fuselage again. I ended up buying a couple more levels so I could cross check the digital ones. Spent some time on this
Left wing poised and ready. Adding boelube to the spar
Both wings on with temp bolts
Leveled lat and long again
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
