More of the same today. Sanded down to the tape. The build up areas took lots of time to sand down. Once Everything was sanded, I decided to try micro baloons again. Mixed up two batches and thickened to minimize sagging in the vertical areas (but not enough!) and applied with squeegee.Covered the sagging areas with some peel ply. Im not sure how this is all going yet but if the waves start to smooth out and the edge sharpens up, Ill think about removing the tape to see how it looks and then retape for final finishing. There is considerable sanding to do yet however!
micro applied after sanding and some peel ply for sag prevention
