No pics of this but I needed something to do while the fairing on windscreen sets up. I took the dremmel with a conical grinding stone and hit every pop rivit in the canopy skirt to rid any sharp edges from rivit stems and the like.
Took 60 grit and glued to wood block and scuffed up the left side skirt in prep for micro. Also used a smaller block to hiyt the skirt lip. The right side still need the work. I noticed while sanding that the skirt is quite wavy and will require some time to get even.
