Brief Description: Canopy center rail slider block redo
Remeasured several times the new nylon block for the center rail. I drilled first with very small bit and drilled up to 3/16 reamer. I then counter bored one side to 5/16 reamer so that the clevis pin will sit recessed in the block. I still need to drill for a cotter pin on the other side but time ran out tonight
New nylon slider block drilled. Notice the counter bored head
New block installed and with proper gap as shown with my gap gauge
