Brief Description: Fix some items suggested by DAR
Today I made some adjustments to engine compartment before reinstalling the bottom cowl. First, I removed the crankcase oil breather line and made a series of small bends and trial placements before finaly deciding on desired placement. Made needed cut to the line and reinstalled so that it terminated just above the left exhaust tail pipe tip.
I then rerouted the scat hgose for the cabin heat and installed a combination of rubber strips and spiral wrap where required to reduce abrasioin wear from contact with other areas in this tight relestate.
I also used some red RTV to seal up any holes and gaps in the engine baffles and then applied some rubber contacy cement to fuse together a couple gapseal fabric verlaping areas.
Finally, I mounted the gopro camera to the front seat back seatbelt bar with camera adjusted to the front panel. This will be filmed during first flight so that the engine and flight parameters can be reviewed after the flight.
