Brief Description: Retest wig wag and reinstall the rt lwr consoe
I spent most the day yesterday with some local help isloating a wiring problem with the wig wag system and then fixing it, and the repaintimng and relabeling it. today I hooked it back up and attached battery to test if the gremlens were still gone. They are! So I hooked all the componets on that panel up and tesrted again and when satisfied, I crewed it down with the nine #8 crews with nylon washers.
I then verifiued that I had installed a inline fuse. It is under the main switch console. I had not made a list of fuse locations and so finding it in logs would be difficult. Made a list to keep in my wiring folder.
I then worked on finding the problem with the ASI light not turning on. After following the wires from the ASI I found where the ground wire was un connected and hidden under a wire bundle. This is what can happen when other things are worked on and diconnections are made. Things can be left out on re assembly. I Attached the wire back to the grnd point and tested. Works again.
Cleaned up the fronty floor boards and put front seat cushions back in.
