Bill & Brendas RV-8 QB
Date:  11-5-2014
Number of Hours:  0.75
Brief Description:  eye bolts added to rudder horm
some 3/16 eye bolts came in that I had ordered several weeks ago. Ive seen where some others have done the install on the rudder horn to decrease the wear of the wire clip on the horn hole. It also makes removal of the tail wheel swag chain easy.
I drilled the hole up to 3/16 and installed the eyebolts and then reattached the chains.
used some safety wire to close up the clips. Ive heard that they can get tangled up at the wheel horn and come loose. Safety them closed should add some security here
