Brief Description: adjust cabin heat cable length and access door scr
Cut some stainless steel machine screws down to 1/2 inch to use to mount the new starter relay bracket. I then sanded up the bracket and cleaned for paint. Primered twice and applied one coat of enamel before going home
Installed the and machine screws in instrument acces door
Cut about 1/2 inch morre from the cabin heat box cable outer sheath and then reattached. Checked operation and it works with out interference now.
