Lighting in hangar too bright for good picture but I powed up the panel with lawn mower battery and bypassing the master relay and the master switch. I was able to check the following:
Trim indicators on trim motors work via hat switch fuel pump powers on and also the gren pump indicator gren light all circular gauges power up with light elt indicator works all map lights and console lights work Both aux power ports operate USb plu operates auto pilot turns on from the new power switch Radio turns on. Radio transmits from push to talk( verified with hand held radio. works fron and back radio recieves as tested with hand held. aux music input works pilot isolate works and noted that music still audible from rear seat Transponder powers on automaticly Transponder dims transponder ident works from both the face plate as well as the pilot stick button
No smoke or funny smells. Guess I can start tieing back the wire mess and start on the engine monitor next
