Brief Description: Gear leg mounting covers cut for clearence and ins
The covers that seal off the mounting hardware for the landing gear did not fit after the brake lines were installed and a relief cut was needed to allow that line to exit. I traced a cut out in the plates and cut out and then rounded with dremmel stone until they fit. It was some back and forth to get the desired clearence without going to far. I then deburred and polished edges up and installed the 2 plates. Done!
Gear attach well covers cut and fitted to allow brake line to exit
