Brief Description: New fuel line from electric pump to gascolator
Fabricated another fuel line from the electric fuel pump to firewall where I mounted the gascolator. After a series of back and forth fitting and adjusting I finaly got it to fit. Tightened up the fittings using flats technique for torque.
Drilled old fuel fitting hole in firewall up 1/8 inch more to accept a metal plug and then snapped it in with biotherm.
Attached new hardware to the MAP sensor and tightened up.
