Brief Description: 12 v aux pwr for back seat install
1. Decided that I would put the 12v auxillary power jack that I got from ACS in the back seat rt side armrest. This will make it easy for the GIB to plug in easy and also the wires will be hidden by the lower panel. To do this, I marked and punched the frill location where I thought it would be best. I then used a unibit that I found at Home Depot that goes up to 7/8 and drilled the hole to 7/8. Deburred and polis the edge.
2. The ACS plug came with an ugly mounting bracket but I could remove it from the body and then slip the body in thru the hole. The top lip keeps it from pulling through. The outer shell then screws on underneath and secures it in place. Presto Manefesto!! Done. The wires will need to be attached but im not ready for that yet.
